94 250 quadrunner oil change help
Old Aug 2, 2009 | 01:58 PM
whitetailslayer's Avatar
Default 94 250 quadrunner operator/mechanic screw ups!
where the heck do I add oil in a 94 250 quad? I have found the peep hole, the drain plug, etc, but can not figure out where to put the oil in. I just got this thing last week.
Thanks!
Old Aug 2, 2009 | 02:30 PM
Okay, I found it, now the question is, what did I screw up?
There was a plug that had a screw with a nut on it. We thought that may be where the oil filter was, so we pulled it out, noticed that was not it.
Okay, everything else is working, except now, when I put it in gear, it will not grab, like the clutches are not grabbing. I can **** it through all of the gears, but it simply will not grab
Help the n00b out lol
Old Aug 2, 2009 | 09:26 PM
jaybeecon55's Avatar
Sound advice there. "Hey, watch this........"
The oil fill is on the right side rear - right around where the right rear axle exits the housing. It's a typical ATV oil cap - not sure what you found with the screw and nut that you did remove.
As to your problem - just a guess but be aware that the motor and transmission share the same oil. If you are suddenly having transmission problems and you used the wrong oil - that could be a likely cause.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
