LTZ400 Top End Rebuild - Piston thoughts?
Old Aug 10, 2009 | 09:13 PM
Soulphire's Avatar
Default LTZ400 Top End Rebuild - Piston thoughts?
Hey All,
I have an 2006 LYZ400 that is going to need a top end rebuild within the next week or so. And since I am at it, should i replace the stock piston with a Wiseco forged?
I don't race the quad, however I do like power (who doesn't).
Is there really a noticable power increase? More maintenance?
Should I go higher compression or stay stock?
Just wondering since I am going to have the work done anyways.
Thoughts?
Thanks in advance!
Old Aug 11, 2009 | 08:28 AM
ss97's Avatar
Lets Ride!
Originally Posted by Soulphire
Hey All,
Thoughts?
Thanks in advance!
It needs a rebuild already? That's actually pretty rare believe it or not for a non-racer.
Either way.....the problem is if you go higher compression you are going to get close to where you need to run race fuel. The stock compression is already 11.3:1 so going up to the next piston which IIRC is 12.4:1 or something might require like 96-97 octane.
There is a chart on the wall at a local speed shop here and 11.0-11.5 is listed as 90-92 octane minimum. I think once you get to 12.0 you are getting into the 95-97 range so pump fuel might not work well.
It depends on what compression you are talking about.
Old Aug 11, 2009 | 01:23 PM
Soulphire's Avatar
Well, I am guessing it needs a top end rebuild. At least that's what the shop says.
right now the only way to start it is jump starting it by popping the clutch in 1st gear.
I will probably go with the standard compression. Just didn't know if I should go with an over-bore or standard.
Also, what are your thoughts on forged vs. cast pistons?
Thanks.
Old Aug 11, 2009 | 08:50 PM
cataway's Avatar
if thats the way it starts ,it needs a valve shiming
STLyamwar
Jul 25, 2020 04:44 AM
kelleycully
Sep 15, 2016 02:57 AM
raceware
Jul 30, 2015 06:59 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
