Sons new toy
Old Sep 3, 2009 | 01:50 PM
CTTJ's Avatar
Default Sons new toy
My neighbor gave my son a LT 185 that he hadnt started since 2007.
He thinks its an 1987. Fresh gas and a little priming and started right up.
My son rode it home. Now it seems that the idle will rise on its own in neutral so high you can use reverse. Other than that theres no starting or riding issues
Whats involved in rebuilding these carbs ?
Thanks
Forgot to mention this thing runs like a dream, good power, no smoke at all, runs smooth through all rpms, all plastics intact, odometer is at 1700 miles
Old Sep 4, 2009 | 07:11 PM
lt500man's Avatar
sounds like a compression leak. that is what causes that problem most of the time.
Old Sep 5, 2009 | 10:29 AM
CTTJ's Avatar
Sorry but could you explain to me how a compression leak will cause a high idle rpm ? There doesnt seem to be any starting problem hot or cold and there is no smoke from the exhaust.
I would like to check out the carb but I just dont like going in blind.
I never worked on one of these mikuni carbs before.
Old Sep 5, 2009 | 12:25 PM
bashr52's Avatar
Those carbs are extremely simple. Check for a vacuum leak around the base of the carb by spraying some carb cleaner/starting fluid, wd40 or anything flammable while the engine is running. See if there is an increas in RPM at all.
Old Sep 6, 2009 | 09:04 PM
lt500man's Avatar
Thats it right on the nail head.
Old Sep 7, 2009 | 08:19 AM
CTTJ's Avatar
I got a chance to realy inspect the carb and air box realy needed a good clean out and had some vacume leaks at hose clamps
No more idle ramp up. Bogs a littlte at the bottom though.
Found out its a 1983 model LT185
Its in remarkable condition we are very pleased
Whitelx1
Oct 2, 2015 10:55 PM
2many2ride
Sep 27, 2015 04:35 AM
kampswas
Sep 23, 2015 05:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
