2008 KQ 400FS backfiring
Old Sep 19, 2009 | 04:27 PM
GaAtvRider's Avatar
Exclamation 2008 KQ 400FS backfiring
My new KQ just suddenly started backfiring VERY loudly sometimes when I get out of the throttle at a good speed and let the motor help me to slow down along with braking. It also will make a soft backfire if I rev it up a little in neutral, and the last symptom it has is when I get it up to temp and let it idle it will purr like a kitten and all of a sudden just shut off intermittently. I already bought a new plug, gapped it, installed it and if anything it made it worse. I did have the 100 mile service done not long ago and it just turned 400 miles today so it leads me to believe that it may be running just a little lean but I wanted to run by everyone here to see if anyone else has had this happen and how you remedied it.
Old Sep 20, 2009 | 10:39 AM
Doctorturbo's Avatar
GOT BOOST!
I think your 100% correct on your lean idea. Sounds lean too me also.
Old Sep 20, 2009 | 11:10 AM
KQ400Pilot's Avatar
Check for an intake leak.
Start with the carb/air box connection, and the air filter/air box connection.
ReconBayou
Oct 31, 2022 05:37 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
rgjackson
Sep 23, 2015 01:53 PM
Brandon400
Sep 7, 2015 12:20 PM
