free mods to 09 KQ 750?????
Old Oct 4, 2009 | 09:01 AM
caseypierson750's Avatar
Default free mods to 09 KQ 750?????
does anyone know of any free mods or cheaper mods to help me get a little more power??thanx
Old Oct 29, 2009 | 08:59 PM
crombyzombie's Avatar
You can shim the primary to get a slightly lower starting clutch ratio. I took a little weight out of my clutch rollers witch lets it rev a little more for a snappier throttle feel. search "king quad clutch mods" for more info
Mark
Old Nov 1, 2009 | 07:57 PM
thanx 4 the info
Old Nov 8, 2009 | 01:32 AM
Bicdaddy's Avatar
The shims are a must, gives you much better low end grunt. Re-route your gas tank vent, and rear dif vent to the pod, and add in-line filters (about $20-25) - also a must, unless you like water in your tank. You can also drill the roller weights in the clutch assembly to increase the lower end grunt, and not lose top end speed. Check out nyrocatv.com for more tech tips if you haven't already.
Customer Service #1
May 15, 2020 08:46 AM
2many2ride
Sep 27, 2015 04:35 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
