z400 wont run
Old Oct 4, 2009 | 04:10 PM
ltz400=junk's Avatar
Default z400 wont run
I have a 2007 suzuki quadsport ltz400 and it blew up and we put a rod rodbearings and piston rings and a jug on it and put it back together by the suzuki lt-z400 repair manual and it is in time and it will crank all day but will not run it trys but just wont....if you have a solution please tell me because i do not want to take it to the shop and pay 75 dollars an hour to have it worked on
Old Oct 8, 2009 | 04:33 AM
dealer374's Avatar
Don't know what you have tried yet. Did you try to PRI first, check to see if you have spark & fuel? Make sure the cyl. was TDC? valve clearance. Do you have good compression?
Old Oct 16, 2009 | 01:43 PM
REmerson228's Avatar
Check the CDI box for corosion, loose terminals, or terminals that may have pulled out of the plug during disassembly. I've had this happen to me.
Old Oct 17, 2009 | 07:05 PM
kfschick89's Avatar
i had this same problem with mine i blew it up and put a new piston and rings in it and lasted about 30 hours so i put another set of piston and rings in it and it wouldnt run had spark fuel and air.... so my teacher in my vo-tec class wanted to do a demonstration about the head and the valves since it was already taken apart and found out that the exhaust valves were not closing all the way so thats why i had no compression. so get a valve spring compressor and take the valves out and spin the velve around the valve seat and you should notice if they are totally closing or not if their not then you need to cut the seats and it should be fine if you do not know much about what your doing then just bring the head to your local dealer and let them do it it shouldnt cost much at all possibly an hour worth of labor if thats not your problem then im sorry i wasted your time and good luck
Old Oct 19, 2009 | 07:08 AM
Talking
A compression test would be the way to go, followed by a leak down test if the compression is low. Sure beats taking off the head to look at the valves.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
