1996 300cc King-Quad - Neutral Won't Engage
Old Oct 6, 2009 | 08:58 AM
frook's Avatar
Default 1996 300cc King-Quad - Neutral Won't Engage
I have a 1996 Kingquad. It was running 2 days ago. I welded on a hand shifter to the shifter. However, when I tried to start it, the Neutral light wouldn't come on. Due to this (obviously) the quad won't start.
I know where the neutral switch is. I shifted the pedal all the way down several times and the neutral indicator still wouldn't come on. I checked all along the wire and couldn't see any breaks or tears.
Can anyone let me know what could possibly be the issue? I honestly have no clue what to do. Is it possible to override this switch or is it mandatory?
Old Oct 9, 2009 | 06:28 AM
faruquehabib's Avatar
it still may be in gear. it is a little dangerous, but you could try pull-starting it to get it running (if it is in gear), then shift into neutral. also, try just physically 'rocking' the wheeler a little forward or back and then try to shift it into neutral. you need to work it a bit sometimes...
Old Oct 10, 2009 | 07:11 PM
Sisco1957's Avatar
Did you disconnect the battery before welding if the shifter was still on the machine. Was thinking the welding could have blown a fuse or caused some problem.
Old Oct 25, 2009 | 06:55 PM
gtboy22's Avatar
Default 1995 King Quad wont go into Neutral
I have the same issue. The last time I started it, I put it inot 1st gear and rode forward. The front left wheel was locked - it would not turn. The bike stalled, and I have not been able to shift it into Neutral since then, so I cant start it. I know the battery, Carby and everything else is OK. It seems that it just wont physically shift into Neutral. Appreciate any feedback if anyone has dealt with this issue before.
95wolv
Sep 27, 2024 12:00 PM
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
2many2ride
Sep 27, 2015 04:35 AM
wendal
Sep 15, 2015 01:50 PM
