05 king quad dies when give the gas
Old Oct 13, 2009 | 06:58 AM
phmixson's Avatar
Default 05 king quad dies when give the gas
i have a 05 king quad somtimes it will die when you give it the gas to go , also wont start somtime not very often, but its stating to happen more common any idears what to do to fix
Old Oct 13, 2009 | 07:46 AM
KQ400Pilot's Avatar
Is the engine fully warmed up before you "gas to go", or is it still cold?
Don't know if your quad is air or water cooled, but air cooled motors are notoriously cold-blooded.
If this is not the case, the symptoms you are presenting could also be caused by the valves being out of specification (probably insufficient clearance).
It is also possible that it is a combination of both.
Old Oct 13, 2009 | 10:15 AM
phmixson's Avatar
its warmed up does not do it all time it is liguid cool and fuel injected
Old Oct 14, 2009 | 03:55 AM
HeftyLefty's Avatar
Check your throttle position sensor, clean your fuel injector, check your engine airbox intake for cracks, and clean air intake butterfly.
Frisky2050
Apr 9, 2020 11:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
