Oil Level Question
Old Nov 2, 2009 | 02:47 PM
texas poser's Avatar
Default Oil Level Question
I have a '98 Quadrunner 500, and have a question about oil level.
I changed the oil Saturday, and put in the amount stamped in the case, 3400 ml. So I put in the 3.4 liters.
The thing is, there is a sight glass on the side with dashes, that I assume are the range of oil level. However, after putting the recomended amount, the sight glass is completely filled
thoughts?
Old Nov 2, 2009 | 04:54 PM
sprayedgt's Avatar
The correct way is to run the engine for about 4-5 minutes, then let it sit for another 4-5 minutes. The oil level should be correct after the engine is warmed up. I would double check the correct oil amount though. Almost a gallon of oil seems like an excessive amount for a 500cc machine.
Old Nov 2, 2009 | 07:44 PM
That's what I thought, and i did some searching around, and I should have gone by the sight glass. The comment was made that, that is the capasity if you break the motor down and truely empty it.
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
panicmanic
Sep 28, 2015 12:59 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
