86 lt230 rear shock
Old Nov 19, 2009 | 02:19 PM
rainman08's Avatar
Default 86 lt230 rear shock
i was wondering if there are other shocks from different models that would fit the lt230 to make the rear more firm. like wud a 250 rear shock fit without doing a bunch of work to it?? thanks in advanced
Old Nov 22, 2009 | 12:42 PM
lt230sman's Avatar
hey lt230E (not S) rear shocks have a firmer spring rate and bolt right up. they also have a nitrogen reservoir which is a bonus too.
Old Nov 22, 2009 | 06:17 PM
NewportHillClimber's Avatar
the E rear shocks require you to drill ur frame and swingarm out to a larger bolt hole. I installed a warrior rear shock on mine and it made a big difference
Old Nov 23, 2009 | 03:11 PM
lt230sman's Avatar
oh i almost forgot about that. i used a 10mm id by 12mm od bushing cut down to about an inch and i used the original S bolt. thats only needed for the bottom, the top bolt is the same as original.
Old Nov 29, 2009 | 05:11 PM
rainman08's Avatar
will the 350 rear warrior shock bolt right up or does it need modifications???
Old Nov 29, 2009 | 05:20 PM
if i modded it it was very minor.
Old Nov 30, 2009 | 06:21 PM
rainman08's Avatar
ok ty guys really appreciate it
Old Nov 30, 2009 | 06:27 PM
rainman08's Avatar
actually one more question do u have the linkage on it. If so can explain how that works if possible to explain. i kinda have an idea how it hooks up but not completely sure if im right.
Old Nov 30, 2009 | 06:45 PM
rainman08's Avatar
actually i noticed that the shock is like a inch maybe a lil more longer will that make a difference??
Old Dec 1, 2009 | 03:18 PM
it is a little longer but when you sit on it it evens out about the same and soaks up bumps better
