ltz 400 big bore kit and hot cams
I was wanting to know if i should put a big bore kit in my ltz 400 and if i should put hot cams in it i have looked at the athena 435 kit that all you do is bolt on thanks.
dude you're killing me!
how many different places are you going to post the same question? You posted in one thread that was 4 years old!
There are other mods you can do first that will do just as much for you. You could get a used FCR and a used set of cams for the same or less then you'll get the BBK for.
If you have your heart set on a BBK look into the Cylinder Works kits. They can be had for under $400.oo if you look around.
Don't expect to be able to beat a 450.....
Would the athena 435 kit be a good kit to put on my ltz 400 and would it cause my engine to have problems thanks.
yes the Athena is a very good kit.....and it will cost you about $200.00 more then the CW kit, which is also a good kit.
no, it will not cause your engine to have problems. Just don't expect too much out of it without doing several other things.
