ozark 250
Old Mar 25, 2010 | 12:42 PM
dbking321's Avatar
Default ozark 250
Hello
im thinking about purchasing a 2002 ozark 250
the only problem is it hasnt been run for a year and the batterys dead
any ideas what i can do to get it running when I am there so i can decide if i would like to purchase it. Thanks
Old Mar 25, 2010 | 01:04 PM
sdride's Avatar
You can still use the pull start or you could jump start it. Be warned though if you hook it up with jumper cables make sure that the vehicle that it's connected to is not running or you will have an issue.
If possible drain the gas that is in the machine assuming it had not been stabilized. Bring some fresh gas with some seafoam mixed in and a try drain the carb. if not bring a can of carb cleaner and give it a good shot before you start it with the fresh gas.
Old Mar 25, 2010 | 01:58 PM
dbking321's Avatar
i dont think im going to be able to tear in to it at the kids house. i was planning on jumping it cause he said it wont pull start since the battery completly dead. i was thinking about bringing some starter fluid and spraying that in when i tryed to start it. Also considerd buying a new spark plug.
thanks for the ideas keep them coming
o and i think the kid is atv challenged
Old Mar 25, 2010 | 03:30 PM
dbking321's Avatar
anyone?
Old Mar 26, 2010 | 06:22 AM
dbking321's Avatar
bumb goin to look at it saterday any help appreciated
Old Mar 26, 2010 | 07:15 AM
sdride's Avatar
Since you can't tear into it you pretty much have laid out your own plan that should be fine. A bike sitting for a year can be an issue if you have no mechanical ability which it sounds like he is in that boat.
Just bring the jumpers and the starter fluid and give it a shot. As long as the machine does not look well cared for or abused make him a low offer due to the neglect that quad is in. Once you own it a quick once over and a full service and cleaning the carb you will be good to go.
I'm sure with a jump and the fluid it will start right up. if it does not the carb will need to be pulled and cleaned.
Have fun it's a great quad.
Old Mar 26, 2010 | 08:12 PM
dbking321's Avatar
thats good i planned on pulling the plug and seeing if it felt like it had good compression and also spraying a shot of fluid down there. then pulling the filter and spraying some directly into the carb. only thing is though can it even run on year old gas?
Old Mar 27, 2010 | 06:35 PM
sdride's Avatar
How did it go? Are you the proud new owner?
Old Mar 28, 2010 | 09:30 AM
dbking321's Avatar
im a proud new owner got it for 1050 bought a new battery cleaned the carb and drained the onld fuel and it fired right up. only problem is i think they might have screwed me over on the title but ill see when i got to the notary on wendsday after calss
Old Mar 28, 2010 | 01:35 PM
sdride's Avatar
Nice and seems like a good price.
