LT-Z400 not starting with starter
Old May 16, 2010 | 07:15 PM
Cnugs400's Avatar
Default LT-Z400 not starting with starter
I have a 2003 LT-Z400 and i can't seem to get it to fire using the electric start...it will push start pretty easy and runs fine after it's started, once it's warm it will usually fire up with the starter...i've cleaned out my airbox and checked the filter to see if i had anything causing a problem there...it's getting fuel into the carb, the carb is clean and working nicely...it's just got me stumped....any ideas would be great
Old May 16, 2010 | 10:39 PM
scrappy312's Avatar
Have you charged the battery?
Old May 17, 2010 | 08:23 AM
spize909's Avatar
adjust valves/checked for cupped intake valves
Old May 17, 2010 | 10:49 PM
Cnugs400's Avatar
Of course
and spize909 thanks i'll get it checked out
Old May 20, 2010 | 08:50 PM
2strokezilla's Avatar
check valve adjustment this happens on the Z400 does it back fire thru carb?
we have had to replace all the valves on ours
Old Jun 5, 2010 | 01:21 AM
1lowzu's Avatar
had the same problem but mine was from a cheap battery it didnt have enough cold cranking amps and i put a new yuasa battery in it but it was to late i the cheap battery took out my 1way starter clutch assmebly
tiresharkdbb
Sep 3, 2017 02:06 AM
clsharky
Jun 8, 2015 11:38 AM
garyt1975
Jun 5, 2015 08:53 AM
vipers
1) Engine problems..
May 31, 2015 09:12 AM
1000gade
May 27, 2015 12:37 PM
