2003 LTZ400 Fuel Issues...
Well here's the deal, when I first crank it up it'll start right up and run fine for about 1-2 mins, and then it just cuts off! and won't start back up unless you let it sit for while, and then again it'll do the samething....
#17
so then its obvously a fuel related issue.make sure the vacuum line from the petcock to the carb isnt plugged, make sure carb is clean, and if all else fails clean the fuel filters and check the diaphram inside the petcock. hope you get it figured out!
