lt 230 running hot
Old Jul 22, 2010 | 04:51 PM
bearl_baker's Avatar
Default lt 230 running hot
just put new rings in a lt 230e it had a dome top piston now it is running hot it didnt run hot befor it just smoked like a 2cycl with too much oil mix
now the motor is running too hot the head pipe dose not glow red
and it has a ping or rattel like sound up top like valves are too loose
what could be wrong?
Old Jul 23, 2010 | 12:35 AM
SeanBean's Avatar
Im not an automotive mechanic, but it sounds to me like the timing is improperly set.
Old Jul 23, 2010 | 09:13 PM
Almost1's Avatar
Ya it's either the timing is too advanced or it's running too lean.
Old Jul 30, 2010 | 12:52 PM
SloStyle's Avatar
I'd pull the spark plug and check to see if its burning white, if it is, I would recommend riching up you air/fuel screw and see if that helps.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
