Lt 230e help
Old Jul 31, 2010 | 11:19 PM
JtN rides again's Avatar
Default Lt 230e help
Planning on doing a top end on my 230e quadrunner. can you get the head off w/out removing the engine from the chassis?
Old Aug 1, 2010 | 08:03 PM
bearl_baker's Avatar
yes it is a littl tight but ti can be done we did 1 two weeks ago
Old Aug 2, 2010 | 05:45 PM
Have any tips for me? Ive got the head free to lift up but the alignment dowels don't seem to want to clear the studs before the top of the head is hitting the neck of the frame
Old Aug 2, 2010 | 06:16 PM
you need to take the alignment pins out of the head use a pair of vicegrips just dont mar it up too bad take out the left one first then you may be ablle to clear the lef and front bolts then twist the the head to the right
Old Aug 18, 2010 | 05:03 PM
Finally got around to working on this again. Your tip about removing the alignment pins from the head worked great, thanks!..
Once we got inside, found the cylinder all scarred, piston skirt is broken away on front and back, and the rod does not pivot freely on the crank, like the rod bearing is junk!! What a mess!! Needs a complete lower end & with the cost of parts/ labor for that I just don't think it's gonna be worth it to fix the quad
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
Nekolai1
Aug 25, 2015 10:04 PM
NewHillBilly
Jun 14, 2015 11:42 AM
tmcauto77
Oct 9, 2010 12:03 AM
