1986 Suzuki LT230E
I Am about to Take apart and fix the Smoking issue with my quad,But I see I may need a few more parts,Yet I don't know the names ofthem to search online... I See the Chain has Jumped off before I got it and Broke the Neutral unit below the front sprocket.Wires still connected and it shows Neutral when idling. I need to know what that Cover unit Behind the front Sprocket that Has the Holes for Mounting a Chain Gaurd so it won't hammer the Motor and crack it.Also I need a O Ring or Seal at the Shift rod,as it leaks Oil there Also...
Close up Pics of the motor on the Chain side would help so I could Sorta Point what area I need.. I can't find it in my Manuel or online.....And may as well Order the part along with the Rings and such to fix it up correctly before I part with it.
Thanks in Advance
Scottie_The_Boy
Thanks in Advance
Scottie_The_Boy
Go to www.cheapcycleparts.com and look at their parts diagrams. They have exploded views of everything, and part numbers and descriptions for everything. I have ordered parts from them, and they seem good to deal with, got all genuine OEM Suzuki parts from them.
got to cmsnl.com and keep clicking until your model come up with diagrams and parts [ I think all parts #]come up -- houseofmotorcycles.com has naerly the same site with prices. these are also good sites if you take something apart and forget how to rebuild
If you search -- quadsport l230s vault -- another good site will come up
Sep 1, 2015 11:59 PM
