2002 suzuki eiger 400 carburetor help
Old Nov 24, 2010 | 12:59 PM
KILLER_K's Avatar
I had to clean out the gas tank, petcock, slow jet and fix the sticking float.
Old Nov 25, 2010 | 08:56 AM
jackpilot's Avatar
Thanks for the update. Glad you're runnin now!
Old Nov 25, 2010 | 09:42 AM
KILLER_K's Avatar
Thanks for the kind words. Only issue i have now s like a small skipping at a certain rpm. I'm thinking since i live in the country i got some bad gas from the store there. As i put a new spark plug in but it is still doing the same thing. Might try some octane booster and see if that helps it out.
Old Nov 27, 2010 | 05:43 PM
Kerbbirds's Avatar
Seafoam might clean it up its the best as far as an additive
Old Dec 5, 2010 | 02:38 PM
  #15
john1422's Avatar
Default 2004 suzuki eiger 400 4x4
i'm having trouble starting my fouwheeler when the engine is cold you have to hold the throttle wide open then release it then it will begin to try to start it had been sitting a while and i drained the float bowl and drained all the gas out of tank put new gas back in it also put a new plug in it once it starts and engine gets warm it is fine it only has 350 miles on it any sugestions?
Old Dec 5, 2010 | 02:45 PM
  #16
KILLER_K's Avatar
Sounds like you need to either check the strainer on the side of the carburetor. If you remove the large hose from the side of the carburetor there is a strainer in there inside the port. If that doesn't help i would take it apart the carburetor and clean it good. As it sounds like something maybe clogged up in the starter jet. Pretty simple carburetor to take apart. I use compressed air and a tooth brush with a little carburetor cleaner to do mine with.
Old Dec 5, 2010 | 02:49 PM
  #17
john1422's Avatar
ok i will try that and see if that will fix the problem like i was saying once it gets warm it starts and runs fine thanks
Old Dec 5, 2010 | 02:51 PM
  #18
KILLER_K's Avatar
Are you using the choke to crank it with? I forgot to even ask about that? I've got to put a starter terminal on mine now as i hate using the pull starter on it. Little thing surely is expensive.
Old Dec 5, 2010 | 03:40 PM
  #19
john1422's Avatar
no if i use the choke it wont start at all
Old Dec 5, 2010 | 03:41 PM
  #20
KILLER_K's Avatar
I see, sounds like you just need a good carburetor cleaning then. Need any help on it let me know.
