whats the trick to start a quadzilla ?
Old Mar 12, 2011 | 06:57 PM
dondeere's Avatar
Always wear motocross boots,they have a stiff sole. Excessive piston to cylinder clearance will make it hard to start. I use to own one!
Old Mar 12, 2011 | 07:54 PM
juko's Avatar
Default 91 lt 250r
it should not try finding the right heat range for your spark plug and ratio air gas two cycle are pretty dtraight forward ski doos are two cycles and their not too bad to start personally i paid my 250r 400 bucks and take three tries to start at -35 and freezing to hell . could be a few things does your carberator stick . old magneto , wrong spark plug heat range for weather,and you top dead piston position is at is absolute highest it should fire to throw it down and not while the piston climbs but should get your book for this .
Old Mar 13, 2011 | 10:23 AM
higganator's Avatar
Cool Quadzilla!
Give it about three half kicks to charge up the capacitor, you will feel it tighten up on compression, Shoule start after a couple of tries.
vipers
1) Engine problems..
May 31, 2015 09:12 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
1000gade
May 27, 2015 12:37 PM
hunt365@home.com
Jul 3, 2000 11:30 PM
250rCanCan
Aug 17, 1999 11:58 PM
