Lt230S to Lt230E motor swap
Old Feb 21, 2011 | 08:55 AM
Nate86's Avatar
Default Lt230S to Lt230E motor swap
Has anyone swapped a 230e motor into a older 230s frame? I'm looking into doing it on my 86 230s. Yeah call me crazy... I know i hate to get rid of the old kick start, but it is for my wife. Has anyone ever done this before? seems like a pretty straight foward swap. Anyone out there in pa want to do a trade LT230s motor for Lt230e motor...
Old Feb 21, 2011 | 10:52 AM
Trailrider230s's Avatar
the S and E model frames are too different for a swap. there is a night and day difference in the frames. the E model frame is an inch wider and an inch longer. you can try to find an aftermarket electric start system for it, i believe GOKI still makes one.
Old Feb 21, 2011 | 10:56 AM
judas009's Avatar
yeha i would think finding an electric start for it would be your best bet
Old Feb 21, 2011 | 11:04 AM
here is the link where i posted pics of the different frames.
http://forums.atvconnection.com/suzu...ort-230-a.html
its on page 2.
Old Feb 21, 2011 | 11:48 AM
Nate86's Avatar
i would really love to have the auto clutch and electric start. has anyone modified the motor mounts to fit? i know i can find a electric start kit but would like to fit the 230e motor in it. i already had someone contact me about a 230e motor and would really like to do the swap. thanks for the input it looks like the front motor mount is the only one different. I could just fabricate a new mount.
Old Feb 21, 2011 | 01:15 PM
Nate86's Avatar
Yeah looking at some pics online and they are alot different. the 230e motor is a lot wider which affects the foot pegs, the brake and shift lever. The 160 that bigcam400 has is a similar swap. the 230e may be wider though. the front motor mount would definitely have to be modified as well as the brake lever, shift lever and foot pegs. I would also need the wiring harness, voltage regulator and the list goes on. Does anyone want to swap me quad for quad for a 230E chain drive or something similar? i have a 86 230s
Old Feb 21, 2011 | 03:30 PM
judas009's Avatar
well if you can find a good machinist or something you might be able to have them make you some custom motor mounts so you could swap the motors.
Old Feb 22, 2011 | 10:42 AM
another thing to consider is that the front motor mount for the E model is that the long bolt that is in the front goes through part of the frame. there is really no way to modify the frame to accept the E model front motor mount. the verticle bars in front of the engine are thinner with a bolt hole welded halfway into the verticle bar on the E and thicker on the S model with the motor mount welded on the side of the verticle bars.
i live about 2 1/2 hours from the PA state line and a buddy of mine wants to get rid of his E model but it needs a little TLC.
Old Feb 23, 2011 | 12:55 PM
Nate86's Avatar
The mount would definitely have to be fabricated lower in the frame, due to the location of the starter motor. It's doable but a little more fabrication than i had hoped.
I live about 4 hours from the PA/OH line if your buddy is willing to travel we might be able to make it work... Mine needs some tlc too (top end/ control arm bushings)... Send me a message if he's interested.
Old Mar 3, 2020 | 03:29 PM
Ken.thomas87's Avatar
Default I live in stl looking for a 230s motor I have 230e motor. Would youtrade.pmedarebuild
I have 230 e motor
