03 Eiger prob
Old Mar 17, 2011 | 01:45 PM
leelee4848's Avatar
Question 03 Eiger prob
I bought a used 2003 Eiger 400 auto this week and I have idle issuses, problem is it will not sit and idle and a little hard to start with or without using choke.
I think it also has a little of a miss to it while riding or like it is reving up and down on its own any suggestions
plan to put new plug, what is the best way to adjust carburetor????
Old Mar 17, 2011 | 04:24 PM
leelee4848's Avatar
Default carbs
Is carburetors a common problem with this model?
Old Mar 17, 2011 | 05:21 PM
BorderCat's Avatar
Yeah, start with a good carb cleaner and saturate carb...may have to dis-assemble but start w/ a good cleaning.
Old Mar 17, 2011 | 06:52 PM
leelee4848's Avatar
Angry more problems
well guys started taking a closer look and I have gas in the oil what now?
I am not happy at all at this ponit any other words of advice
Old Mar 17, 2011 | 07:37 PM
Jaster94's Avatar
your float is stuck. quad is still good. carb needs to come off, we can help you out with the minor repair. while apart, we'll get you to clean the carb and jets. then change the oil in the crankcase, you'll be ready to rocknroll.
Old Mar 17, 2011 | 07:49 PM
leelee4848's Avatar
Well I have the carb off do you think I should go ahead and rebuild it while I have it this far so I dont have to do this again anytime soon?
Old Mar 17, 2011 | 07:55 PM
Jaster94's Avatar
sure........you could save some money, clean it really good, check out the float action, clean the jets, slap it back in and, BAM, it's good to go. as you can tell, it's not too difficult to remove the carb. you could always pull it again later and rebuild it. OR, just do it now. either way, it'll work.
Old Mar 18, 2011 | 11:02 AM
BorderCat's Avatar
I may be overstating the obvious...but make sure you change the oil & filter & plug.
Old Mar 18, 2011 | 03:15 PM
leelee4848's Avatar
Default Really
Okay just cause I am a girl I am not that dumb, thanks for the reminder but really......thanks for all the replies to my problem I have ordered a rebuild kit for the carb, let you know how it goes hopefully I will be slingin' mud soon
Old Mar 18, 2011 | 03:37 PM
BorderCat's Avatar
Hey leelee, sorry I actually didn't know you were a girl...guys do dumb sh*t all the time.
