2001 Quadrnr + electric fence = dead? Help please :(
Old Jul 26, 2011 | 07:27 PM
Murfx's Avatar
Unhappy 2001 Quadrnr + electric fence = dead? Help please :(
I have a 2001 suzuki quadrunner 160. My sons 1st attempt to ride it and he drove it into the electric braid horse fence. Now, even though it is in neutral, the green "neutral" does not come on and starter makes no sound and does not turn the engine.
What electrical is on this the fence has probably shocked and blown out?
Any idea how much the part is and would it be hard for an amature to replace?
Thanks for any advice.
Old Jul 26, 2011 | 09:24 PM
Scooter86's Avatar
Knows Old ATV Questions!
Is there a fuse in the starter relay? I would try there first.
Old Jul 27, 2011 | 08:15 AM
Murfx's Avatar
Thanks, I'll try and find a fuse.
Old Sep 24, 2011 | 03:40 PM
Murfx's Avatar
More help needed please. Ok, I finally got time to check it out. The fuse is fine. The problem was the terminal on the end of the battery wire was rusty and the (+) terminal wire broke off where it attaches to the battery post. So I need to get a new terminal and attach it to the end of the wire.
HERE'S MY QUESTION:
The battery post is the weirdest battery post I've ever seen. It is like a square with holes in each side. So I try to take the screw out of the top, but it is impossible! It goes thru the post and has a nut on the bottom. I've tried jamming a screw driver in the hole to hold the nut still so I can remove the screw, but the nut just spins and so I cannot get the screw loose (and the hole in the post are too small to get a wrench into).
Could someone please tell me the secret holding the nut inside the post so the screw can be removed?
Thanks
Old Sep 24, 2011 | 04:34 PM
woodsidewarrior's Avatar
That should be a square nut sounds like someone replaced it Try 2 small screwdrivers going in one grime each side. All yeah you may need to grow an extra hand for this
Old Sep 24, 2011 | 04:49 PM
faruquehabib's Avatar
just cut the bolt with a dremel and replace it
Murfx's Avatar
Thanks, I'll try that.
I see now that apparently this what ATV batteries look like. See this link for a picture:
HOW TO: BATTERY MAINTENANCE | News |
Old Sep 27, 2011 | 09:46 PM
Murfx's Avatar
Being the bolt is inside the "Box", even a new bolt would be hard to tighten as you cannot grip it.
Surely there is a prescribed way to undo these things. I don't know why they couldn't make the terminals simple like a car battery!
Thanks
Old Sep 28, 2011 | 07:51 AM
scootergptx's Avatar
Supersock
Hired Gun!
It may be worth the investment of a new battery. The new one will have the rectangular bolt that goes in the open slot, and you'll see it can't spin when the bolt goes through it.
Hopefully, the quad took the shock from the fence and not your son.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
chewy78
Sep 8, 2015 10:37 AM
lancemll88
Sep 6, 2015 03:03 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
