cam boss?
Old Mar 18, 2001 | 06:30 PM
coyote2's Avatar
What is a cam boss & what does it look like?This is on a 1998 ltf500.Trying to set the timing.
Thanks,Joe Wiley a.k.a. coyote2
Disregard this I've found out what it is.
Thanks anyway.
Old Mar 18, 2001 | 06:57 PM
ecorman1's Avatar
I'm not sure but it usually indicates a raised area like a bump on a smooth metal surface. Maybe you should consider letting someone else do this for you. Or purchase a manual. But don't screw around with it if you're not mechanically incline, like working on the old dirt bike? I speak from experience, I've wrecked a few pieces of good equipment in my time.
Chuck
Old Mar 18, 2001 | 07:33 PM
Tree Farmer's Avatar
ecorman1's correct; sometimes, an enlarged part of a shaft . . .
Sounds like you're looking for a timing mark.
Regarding valve timing, a ballpark hint:
Get the piston at top dead center (from marks on the rotor, or: stick a wire in the spark plug hole and feel when the piston reaches its zenith).
Then, rotate the cam until both intake and exhaust valves are totally closed; the rockers face totally the low side of the cam lobes--you are now VERY CLOSE to correct valve timing, if not right on.
Tree Farmer
oliveiracarlos
19
Nov 11, 2015 05:49 AM
merryman
Sep 19, 2015 03:15 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
