Help
Old May 25, 2012 | 10:47 PM
RM EIGER's Avatar
Default Help
I bought A 2005 suzuki eiger 400 and i cannot get the front headlights to work ..I do not no much about these quads but i learn fast i do no that when i bought it was not running so i check fuses and i found the 30 amp fuse blown so i switch it and it started no problem .....then i check they other 10amp fuse and the high beam fuse was blown so i switch it out and still nothin >>>>then i check for power at lights no power then i check fuses and im not getting any power on the one side of the fuse panel for the lights ....sooooo i ran power from battery to top of fuse and bam lights cam on but really dont want to mickey mous and have a chnce of fire or somthing any suggestions on what to do or check ??????
Old May 29, 2012 | 06:31 PM
Rancher247's Avatar
I assume you turned the key all the way over to turn the lights on?
Old May 29, 2012 | 10:13 PM
RM EIGER's Avatar
Ya figured out the ignition was not good but got it figured
