230 QUAD RUNNER
Old Mar 19, 2001 | 03:21 PM
maxdad's Avatar
I HAVE A QUADRUNNER AND THE STARTER WON'T WORK. IT SEEMS THAT THE NEUTRAL SWITCH IS NOT WORKING DO YOU KNOW WHERE IT IS LOCATED AT?
Old Mar 19, 2001 | 10:35 PM
bermbanger's Avatar
if i'm right its its inside the cases-lower end
Old Mar 20, 2001 | 07:30 AM
maxdad's Avatar
I'M PRETTY SURE I FOUND IT, CAN YOU JUMP IT OUT SO THAT THE STARTER WILL RUN?
Old Mar 20, 2001 | 05:00 PM
bermbanger's Avatar
yea you can jump the wires. when you do that the starter will work and it will also start in gear
where is the switch at?
Old Mar 20, 2001 | 11:12 PM
rmx251's Avatar
Bermbanger, are your blue a-arms longer than factory? Where did u get them and how much?
Old Mar 21, 2001 | 05:41 PM
bermbanger's Avatar
No i got tired of looking at the stock ones so i took everything off and sanded them. Then i primed them and then used some krylon true blue spray can paint and put a few layers on them. And then 2 layers of clear coat. They look awesome and match really well to the red shocks and i also painted the bumper blue.So far none of the paint has came off.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
vlkster
Jul 28, 2015 11:35 AM
Chillibean
Jul 26, 2015 09:47 AM
