Low Fuel Death Rev?
Old Aug 14, 2012 | 10:06 PM
PinkFloydEffect's Avatar
Lightbulb Low Fuel Death Rev?
Why does my LT250 rev out when it runs out of fuel? Lately it seems like I have to ride on reserve no matter how much is in my tank, I have a clear fuel line so I can see it still get fuel set to ON and not reserve. Today I ran out of gas, it started idling higher and wouldn't stop I had to end up running it down in a high gear because the kill switch didn't work. It's not sucking in air I rode it all day just fine, recent complete rebuild I've only taken it out a few times. Is this a petcock problem?
Old Aug 14, 2012 | 11:04 PM
2strokezilla's Avatar
Two strokes do that when you run out of fuel. But its an easy fix.
Old Aug 14, 2012 | 11:14 PM
That's crazy, they lean out?
Old Aug 15, 2012 | 08:53 AM
Scooter86's Avatar
Knows Old ATV Questions!
Yes, yes they do. Oddly enough, my LT's were more likely to do this. The one time I ran the TRX out of fuel, it was running normal and just died.
Old Aug 15, 2012 | 09:43 AM
What causes this? Air bubbles in the fuel line?
Old Aug 16, 2012 | 07:30 AM
Scooter86's Avatar
I can't attest to bubbles in the fuel line. 2 strokes are just more sensitive to changes in air/fuel mixture than the 4's. When you get down to those last dregs in the tank it is not replenishing the float fast enough. Same amount of air + less fuel = lean condition.
Also, you may well have some debris in the tank and/or petcock that is clogging the fuel flow.
You could always dump the clutch in a higher gear with the brakes on, should kill it if it is running away.
ltrmc02
Aug 22, 2021 02:34 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
