2007 Eiger 400 4x4
Old Nov 24, 2012 | 08:14 AM
Leighton's Avatar
Default 2007 Eiger 400 4x4
Front camber is off. Is this adjustable? If so, any guidance will be most appreciated.
Old Nov 24, 2012 | 09:26 AM
RonV's Avatar
In at the top or bottom? Are your bearings toast? Bent upper or lower control arm? I don't believe there is any adjustment.
I've had to replace the front wheel bearings a couple times and when they go, that will cause a camber problem.
Old Nov 24, 2012 | 10:23 AM
Leighton's Avatar
In at the bottom on my 07.In at the top on my 04.Can't see anything bent and sure bearings are good on both.Friends have told me a arms but like I said can't see anything bent.
Old Nov 25, 2012 | 08:16 AM
RonV's Avatar
You can look for cracked paint, or signs of rust on the a-arms and frame to see if has been bent.
Old Nov 26, 2012 | 01:50 PM
Leighton's Avatar
Thanks will check
Old Nov 30, 2012 | 02:03 PM
Leighton's Avatar
Looked and cant see rust. If the camber is in on the top or bottom would it tell you witch arm to replace?
Thanks again!
Old Nov 30, 2012 | 05:22 PM
RonV's Avatar
Lift up the front of the atv and drop it. Then take a pic and post it.
Old Dec 1, 2012 | 04:56 PM
beart0y's Avatar
Was your 04 one subject to the poor weld at the bottom of the front of the frame? I think Suzuki USA did recall on that for you. Mine had the fault and was fixed when the frame was re-painted.
Whether this, alone, would cause camber problems not sure.
Old Dec 2, 2012 | 07:43 AM
Leighton's Avatar
Please advise as to how to add picture. Can't figure it out!
Sep 23, 2015 06:23 AM
ylomnstr
Sep 22, 2015 12:19 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
ylomnstr
Sep 4, 2015 05:02 PM
