'03 ltz400 Fuel issues??
Old Apr 21, 2013 | 03:13 PM
Loyalist's Avatar
Default '03 ltz400 Fuel issues??
I have looked in other threads but ied figure ied ask anyhow due nothing working..this is whats happening . The bike will start and idle just fine but when i rip it up and down my street wide open up through throught 4th ( road is short cant hit 5th lol) I can only get a few passes then it starts backfiring/popin out exhaust on decel then it will start stalling out when i pull clutch or hit nuteral . it will start back up fine after a min but run like crap till i let it sit for a while... might anyone have anythoughts on whats goin on..to me it seems like not enough fuel..tank vent is not clogged im runnin on "prie" on petcock...any ideas on what maybe goin on?
Old Apr 21, 2013 | 03:32 PM
h0ndadude362's Avatar
had this same problem 2 weeks ago with my 03 z. play with your air fuel mixture screw on the bottom of ur carb turn it out. sounds like ur running lean as all get out. also take ur carb out and remove all jets clean them and re install. good luck
Old Apr 23, 2013 | 07:48 AM
mla2ofus's Avatar
Check the valve lash too. Could be the exhaust valve not closing completely when everything warms up.
Mike
Old Apr 24, 2013 | 10:23 AM
Loyalist's Avatar
Question: does the fuel/air mix screw regulate how much fuel goes into the bowl? a friend with the same unit said his did the same thing and like h0ndadude362 said to adjust the screw to get more fuel to flow into bowl at WOT? does this make sense to anyone?
Old Apr 26, 2013 | 04:49 PM
Loyalist's Avatar
Pulled plug...its black soot..more on the dry side..its showin rich...maybe turn in air/fuel screw a bit? im going to check out petcock shortly...after it stops rainin that is..
Old Apr 27, 2013 | 01:16 PM
Loyalist's Avatar
I just checked petcock and when i pulled the vacuum line it was dry but when i pulled the fuel line off fuel was coming out no matter what position it was on.. would fuel still trickle out when its on "res" or "on"? its not coming out fast but its still tricklein..I really dont want to pay 100$ for a petcock if i dont have to..im going to try to adjust fuel/air screw before i pull carb.The quad has a 150 jet i was told and K&N filter with lid off also aftermarked slip on exhaust.. is it possible for someone to tell me about how many turns out for fuel/air screw?
Old Apr 27, 2013 | 01:35 PM
Loyalist's Avatar
Im sorry but another question about the spark plug. I pulled out a NGK CR7E but depending what website i look at they are sayin its a CR7E ,CR8E and CR9E.....I called a parts store and the guy told me the CR7E doesnt fit?? and i need a CR8E..This shouldnt be this hard to get a dam plug..Can anyone please recommend a plug size...
Old Apr 30, 2013 | 01:13 AM
biz4two's Avatar
Arrow
Regarding the plugs...the size of the plugs are all the same. The lower the number the colder the plug. The higher the number...the hotter the plug.
So...
CR7E = Colder
CR8E = Mid
CR9E = Hotter
IMHO...Might want to start in the middle...and see how it goes. Hope this helps...
biz
Old Apr 30, 2013 | 01:17 AM
biz4two's Avatar
Arrow
Essentially the fuel/air mix screw is to FINE tune the fuel/air. It is not meant to radical adjust the carb. For that...adjusting the jets is recommended.
biz
Old May 7, 2013 | 12:15 PM
Loyalist's Avatar
FIXED!!!!!! Well i put on a new petcock and went wide open up the street and it still had its little fit i limped it home and tried to drain the bowl and barely any fuel came out!! so i said screw it and took carb off to check it out..Come to find out the needle for the float was clogged with crap to the point i was barely able to even blow air through it..I took it off cleaned the needle and its port and BAM no more stalling!! did like 6 runs up and down the street and didnt stall once!!
