Ozark 250 hard to shift
Old May 28, 2013 | 08:10 AM
timbassman1's Avatar
Default Ozark 250 hard to shift
Hi, I recently bought my son a 2003 Ozark 250 he is have trouble shifting from neutral to first any ideas as to what it could be?
Thanks in advance Tim
Old May 28, 2013 | 09:20 AM
TLC's Avatar
TLC
My 250 Yamaha Moto4 was very stiff and notchy to shift with boots on. I switch the oil from conventional to full synthetic. After that it always shifted smooth even with sandals on.
Beats me why,but it did the trick.
Old May 28, 2013 | 09:36 AM
I am planning to change the oil today anyway, so I will use full synthetic, I will repost with results. Thank you TLC for your help.
Old May 28, 2013 | 10:18 AM
TLC's Avatar
TLC
Just make sure you use a motorcycle grade Snythetic made for wet clutches. Amsoil is a good one of many.
It should state if its for wet clutches right on the lable.
Old May 28, 2013 | 10:41 AM
papahouse's Avatar
Also check your idle rpm, it should be set to a low rpm at idle for ease of shifting.
Ridgerunner665
Sep 15, 2015 01:20 AM
bvolks
Sep 13, 2015 12:57 PM
essonlaker
Sep 10, 2015 01:12 PM
that1redhead
Sep 8, 2015 11:47 AM
Elkaholic
Sep 6, 2015 02:44 PM
