1992 Suzuki 230 identification help?
Old Jun 5, 2013 | 07:07 PM
Ghart321's Avatar
Default 1992 Suzuki 230 identification help?
I just purchased a Suzuki Quad. Can someone help me identify it please? The number on the frame is JS AJ 43A4H2104319. The number on the motor is J411-149464. Is it a 1992? What model is it? Is it a two stroke or 4 stroke?
Mike Hart
Old Jun 5, 2013 | 10:56 PM
MIsuzukilt230s's Avatar
Welcome to the forums!
The serial # that you posted looks to be a 230cc motor. What color are the plastics? Does it have front and rear suspension? Kick start? Pull start? Electric start? Manual clutch? Semi auto clutch?
I doubt it's a 1992 model but it is possible. Post up a pic if you can.
The frame should have a 17 digit vin number. The one you provided only has 16. Check again and we'll go from there.
Old Jun 6, 2013 | 12:45 AM
Ok I did a little research. Your vin most likely is JSAAJ43A4H2104319 (double check yours to see if the 3rd and 4th digits are AA).
1st digit: J = Japan
2nd digit: S = Suzuki
3rd digit: A = ?
4th digit: A = ?
5th digit: J = 200-249cc (230cc in your case)
6th digit: 4 = 4 stroke single cylinder
7th digit: 3 = ?
8th digit: A = ?
9th digit: 4 = check digit used to verify the vin is not phony
10th digit: H = 1987 model year
11th digit: 2 = factory(plant) code
12th-17th digits: 104319 = serial (sequence) number
I have a 1985 lt230s. Compare your vin and engine serial # with mine (JSAAJ43A6F2109759, J411-149551). With just the info you have given so far my guess is that you have a 1987 lt230s quadsport.
Old Jun 6, 2013 | 04:04 PM
Ghart321's Avatar
Thanks for all your help.
JSAAJ43A4H2104319
It is blue and white.
It has front and rear suspension.
Kick Start (kicks out away from the motor not to the back like a regular Motorcycle)
Manual Clutch
Compression Release for starting.
Reverse
Nosniborpapa
Sep 19, 2015 07:07 PM
merryman
Sep 19, 2015 03:15 AM
Sep 1, 2015 11:59 PM
