I got this lt185 running (and dies once I hold the clutch or compression/decompression handle in) anyways while its idiling gas starts coming out of the hole provided in the picture.. Is this normal if there is too much gas or is it a gasket thing? Does this also mean the carb is getting flooded too? If I have the fuel **** set to off, only very little comes out, once I set the fuel **** is turn to on position it comes out like a steady stream.
I took the carb off, and brought it with me home (atv is at a friends house) and the carb looks clean from a quick inspection.
I just inspected the carb, and the carb was clean, I still ran carb cleaner though, the diaphragm to the primer was cracked and has a hole in it. Looks like I just need to replace the primer.
