Need some help changing the oil.....
Old Oct 5, 2001 | 03:45 PM
XtremeVette's Avatar
Hi, names Jeff and Iam new to the forum,
I have a 2000 King Quad and unfortunately as of yet, no service manual. Not sure how to change the oil... & along with any other recommendations for me to do or check would be great. This is the quads first check up on its vitals. Just over 100 miles right now...
PS what type of oil should I be using and how much do I get?
would the air filter be
ok too?
anything Iam missing please post.....
thanks guys
Old Oct 5, 2001 | 06:18 PM
mudmanatv4x4's Avatar
i just sold my 95 king quad but here we go.
put a pan under the drain plug which is located under the rear skid plate. open the oil fill plug which is in the back if it is tight use pliers(this is for more oil flow). now, unsrew the drain bolt with a ratchet. becareful oil will pour out, let it drain for 15-30min. and when no oil is pouring out make sure the kill switch is off and key is on off, and pull the recoil a few times which is under the seat. oil will flow out. you air filter should be cleaned and oiled, the first thing i did was purchased a k&n filter. the stock king quad filters are junk. hope this helps tell me how you make out.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
