I AM THE SMARTEST MAN ALIVE!!!!!!!
A while back I posted about using 5th wheel grease (for a big rig) for A/swing-arm bushings/bearings, and decided to try it. After I packed the swing arm bearings right chock-o-block full, it took quite an effort to push the bolt through(motor's out at the moment). The grease has the consitency of Bondo, and I still ain't got it completely out of the crease in my fingers, but I definately think that it will be quite a while before the grease in the bearings need replacing/repacking. Again, I don't think it'll work good for the high speed/heat wheel/axle bearings since it ain't a high temp grease, so someone else can try it before I do, but it'll surely outlast regular grease in the bushings....
No I will not make out with you![img]i/expressions/face-icon-small-disgusted.gif[/img]
Did ya hear that everybody she wants to make out with me in the middle of class, you got chloraphyl man up there talkin about God knows what, and your back here wantin to make out with me, I came to school to learn, not to make out with you, Go on with the chloraphyl![img]i/expressions/face-icon-small-happy.gif[/img]
