Overflow hose on Quadzilla
Does it drip while the fuel is turned on but the engine not running? If yes then you probably have bad needle an seat. The way to check it is to remove the bowl( you can do it by loosing boot screwws and turning the carb sideway's) put the carb straight put your finger on the float arm and lift up lightly, if fuel continues to flow while the neddle is closed then you need a new needle and seat.
I responded to someone else's question the same BUY A KEIHIN AIR STRYKER best money I ever spent.
Take Care
Take Care
When I leave the gas on and my zilla is sitting gas drips out. If my needle needs replaced would that possibly cause me to foul plugs? I foul plugs regularly but not as bad since I upped the octane of fuel and went to synthetic premix.
jrooker6
Apr 23, 2016 07:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
