transmission question (lt250r)
Old Dec 9, 2001 | 05:30 PM
chuck1221's Avatar
I have a 91' suzuki lt250r. What is a good oil to use in my transmission? I will be putting it back together pretty soon with a new clutch, is there anything I need to know about putting a new clutch (plates and springs) in? Also, I need to find a place to buy a piston for it. I need one that is .75 mm over or .030 in. any help would be greatly appreciated.
-chuck
Old Dec 9, 2001 | 07:56 PM
ineeedabudlight's Avatar
I use Bel*Ray Gear Saver 85w transmission oil. Its made for 2-stroke transmissions.
Danno
Old Dec 9, 2001 | 10:11 PM
chuck1221's Avatar
I also found a place to order my piston. I bought it today from rocky mountain atv.
-chuck
Old Dec 10, 2001 | 06:42 PM
Kadafiy's Avatar
Soak the clutch plates in oil prior to installing them.
Old Dec 10, 2001 | 11:46 PM
URnotRoscoe's Avatar
Don't run 85W oil in your tranny if you plan on riding in cold weather. In Wisconsin I usually run 30w or 40w don't run anything heavier it is simply too cold and the oil gets too thick. Don't over torque the bolts with the springs, the fingers in the basket WILL break off if you over tighten, check the torque specs.
NewGuy2481
Oct 6, 2015 05:54 AM
cornermike
Sep 10, 2015 08:30 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
Sep 7, 2015 09:42 PM
