Quadzilla Oil Mix & type
Old Jan 5, 2002 | 09:47 AM
truckracer's Avatar
What are you guys running as a mix ratio? What brand of oil?
I ran Maxima Super M a very long time ago but it's not readily avaiable in my area anymore. I checked the local stores and I a seriously considering using the Pennzoil marine synthetic mainly because it is a full synthetic and its in just about all the places I checked.
Thoughts on this???
Old Jan 6, 2002 | 01:06 AM
Chapy's Avatar
I made the mistake of going with an oil like you are thinking about. I highly recommend not using a marine oil. I run Maxima 927 at 32:01 ratio.
The bad thing about this is that maxima breaks down in cold weather so in the winter I'm going with golden spectro at 32:01. When I ran "bad" oil my zilla ate spark plugs really bad I took 6 plugs with me when I went ridin. If I doesn't get real cold go the the Maxima 927 I had great results. I also use JP1 octane booster 2 oz. per gal. That made a big difference too.
Old Jan 6, 2002 | 02:56 AM
Slinger's Avatar
927 at 32:01
Old Jan 6, 2002 | 03:43 AM
quadwoody's Avatar
man i use Yamalube in mine. 32:1. Does great. I was also told that using Mobil 1 in the crankcase is good too. Mobil makes a motorcyle oil for higher rpm's but i was told to use the formula for cars. I dont personally know it was just a tip from one of our engine builders.
Old Jan 6, 2002 | 01:35 PM
waynaferd's Avatar
I like the Klotz syntec blend myself......along w/ the cool odor that has people asking "What the hell's that smell?"
Old Jan 6, 2002 | 05:05 PM
stormnorm's Avatar
40:1 Bel Ray H1R full synthetic fantastic results since
87 QZ
87 QS
Old Jan 7, 2002 | 04:20 PM
FAST453EX's Avatar
32:1 Klotz BeNol, this stuff smells like no other, the "extra virgin castor oil" smells like a top feul drag car, Maxima 927 smells similar but not nearly as potent, i love it but below freezing I run golden spectro because BeNol is too thick.
Old Jan 7, 2002 | 09:43 PM
VegasQuadracer's Avatar
Isn't Mobil 1 a synthetic. If it is I wouldn't use it. I've read in these forums more than once that synthetic will eat up your gaskets. It was recommended to use natural oils without any synthetics.
Old Jan 7, 2002 | 11:09 PM
quadwoody's Avatar
yeah Mobil 1 is a full synthetic, i haven't used it,so i wouldn't know personally. It was just a tip that our engine builder gave us, and it's only to be used in the crank case (like i said) it's suppose to be better on the clutches. if anybody knows first hand then please share info
Old Jan 8, 2002 | 12:12 PM
Xteife's Avatar
Mine's bored 50 over and was told by the guy I bought it off of to run 40:1. It really seems to smoke though. I also see a lot of oil splatter coming from the exhaust joints. I'm pretty new to 2 strokes and was wondering if this is relatively normal. Other than that it runs great though.
