What is everybody doing to fix the head gasket problem on the '87 LT500?
A common problem of the '87 LT500 is the head gasket failure.
The '87 only used 6 head studs (vs. 7 on the 88+ models)
Anyone have suggestions on the 'best' way to fix the problem on the '87??
I understand Trinity welds and machines grooves for O-rings in the stock head,
Others recommend upgrading to the 10mm studs from the 88+ machines, and then there are the aftermarket LRD/ProDesign heads that use O-rings..
What works and what doesn't????
Copper Rings? Viton/Rubber rings? Copper head gasket??
I'm building a monster motor, and don't want the hassle of the gasket game.
My stocker has been trouble free, but I understand that when you boost compression and hot rod this motor... the gaskets can't haul the mail.
Any ideas?
Any ideas?
Not necessarily.. The stock head can be milled a mile to really bring up the compression, the chamber can be re-shaped to just about anything you want...
The sky is the limit when you have a good machine shop at your fingertips.
I'm assuming you're running a cool head fasternu?
The fix to your problem is to install the larger 88 and up studs and always use a oem head gasket....
Mick
88 LT 500 +
Wisco pro lite
40mm bore PWK
Paul Turner High Rev & Fat Boy
Nac's Flat Track, Ice Race Port & Head work
Crank Trued Welded & Turbo Radi.
Mick
88 LT 500 +
Wisco pro lite
40mm bore PWK
Mojave250A
Jul 11, 2015 10:38 AM
ranvette
Jul 4, 2015 06:13 PM
