wont start
Old Feb 18, 2002 | 04:57 PM
ATVRYDER's Avatar
I have a LTF 250F Quad Runner The electric start does not do anything none of the pod light turn on, but all the front and rear lights work. I have checked all fuses but everything looks fine. It acts as like it was stuck in gear but it is not. Please HELP!!Thanks
Old Feb 19, 2002 | 10:54 AM
Thespazardman's Avatar
I KNOW this sounds stupid, but: disconnect the battey, clean/service the battery (maybe even put it on the charger), clean the wire ends (wirebrush), and reconnect. The pod lights, and the starter draw considerably more current than the runnng lights, and corrosion (whether it's visible or not) at the battery often prevents large current draws, and effectively showing problems like yours.
This is always the first thing I check when I run accross problems like this in cars or atv's. Its the most common electrical problem I've seen, and the cheapest fix [img]i/expressions/face-icon-small-smile.gif[/img]. Always start simple.
Thespazardman
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
