Zilla Motor rebuild Questions?
Old Feb 25, 2002 | 02:12 AM
Chapy's Avatar
I have a few motor rebuild questions for my Zilla?
How do you remove the clutch sleeve hub, my manual says you have to have a special tool? And the book says you have to have a tool to split the cases. I have plenty of tools but not these 2 specific tools. Is there a way around this? Or what you you guys done?
Old Feb 25, 2002 | 09:58 AM
lt250qracer's Avatar
I have a lt250 and when I remove my clutch hub if the moter is in the bike put it in a high gear and hold the brake. You might need someone to hold the tires as well. this will put a lot of strain on the engine gears but I have never broke anyting in mine. if the engine is out of the frame put the spoket on and put the sproket in a vice. again this will put strain on the gears but this is the only way I no how to do it. I have never used the correct tools to split my cases. Just be gentle and don't pry it with a screwdriver. hope this helps. good luck!
Old Feb 26, 2002 | 01:55 AM
Jason454's Avatar
Usually you can work the cases apart. The clutch nut will come right off with a impact gun. Just make sure your going the right way.
Old Feb 26, 2002 | 02:06 AM
Chapy's Avatar
How do I get the magneto rotor off with out buy the "special tool" I got the nut off already. It should pop off but I can't get any thing in to pop it off.
Old Feb 26, 2002 | 05:37 PM
stormnorm's Avatar
Believe me!!!! It will not pop of!! You will need that tool. Being a machinist I made my own puller tool for the flywheel. I keep it close by and it works remarkably well. Even with this tool it doesn't pop off. It comes off with a loud bang. The tool has a left handed metric thread on the outside and a regular thread for pushing with a 1/2 in. bolt turned to a sharp point in the centre of the tool. I should market these things and make a killing even selling them at a fraction of suzukis price.[img]i/expressions/face-icon-small-wink.gif[/img]
87 zilla
87 Quadsport
Old Feb 27, 2002 | 01:28 AM
Chapy's Avatar
I believe you norm, I stripped out my conventional flywheel puller after I made some mods, to it to fit. And that thing didn't move I'm takin it to my suz. shop tomorow Thanks any advice will be appreciated.
Old Feb 27, 2002 | 09:46 AM
2strokesrule's Avatar
Heat up the flywheel with a torch, it will pop off with the puller.
kelleycully
Sep 15, 2016 02:57 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
yambam13
Jul 4, 2015 01:49 PM
