QUADZILLA GUYS PLEASE HELP!?!?!
Old May 21, 2002 | 10:42 AM
Jason454's Avatar
I am leaving to Idaho next week and need to fix my air leak. When I put pressure in the motor, air starts leaking out the exhaust valve into the crank case. It leaks past the small oring. It will seal after a little time(applying the air pressure) but then after I ride it slides over or something then starts leaking again. There is enough room on the exhaust valve shaft to put two orings on it(between the bearing and the retainer) would that help? I know it would keep it from sliding around. Yes the oring is brand new from Suzuki. Please help if youve seen this problem. Thank Jason
P.S. Im talking about a lt500r 2 stroke Quadracer.
Old May 21, 2002 | 06:37 PM
500Quadracer's Avatar
One of the people gave me a website with helpful LT500 building info. I came across something that might point you in the right direction. Here is a cope and paiste of what i read that made me think about your question. "LT500 which is equipped with a complex power valve, frequently they will leak through them. Particularly if the O-rings are old or worn. This is not terribly serious but an indicator you should service/overhaul the valve." You might not have a serious problem with the blow by and loss of air pressure so the overhaul might be what you need by a good mechanic. Hope this helps you some with your 4 wheeler.
Old May 22, 2002 | 04:23 PM
waynaferd's Avatar
What do you mean on the shaft? I know there's one on the left hand side on the adjuster-****-thingie, and one on the piece where the linkage hooks to. Is your set screw in the bottom of the cylinder in the indent on the valve? If it wasn't, that's the only thing I could think of that might let it slide.....
bafisher1986
Jul 21, 2015 04:12 PM
rcappie4
Jul 18, 2015 07:51 AM
Robinhood
Jul 13, 2015 09:13 PM
Edgeslade
Where to Ride
Jul 10, 2015 05:08 PM
