Everest 800 soon to be released?
Old Jun 13, 2002 | 04:12 PM
LEP7MM's Avatar
It will have a locker front, with similar electronics as the Vinson. It also sports 8 inches of wheel travel front and rear. Claimed 48 RWHP with GOBS of torque out of this V-twin based on the successful Prairie 650. Extra low gear for rock crawling. Will also be available in both auto or 4-speed manual configurations. The frame will be a hydro-formed aircraft aluminum box style frame with full protection on critical areas such as A-arms and under the frame. Other light weight componentry will include hollow drive shafts, hollow crankshaft, aluminum rims, A-arms and a beefed up version of the swing-arm found on the Prairie 650. Claimed dry weight is 579 lbs.
And now that I made all of this up, what else can anyone else add to the list that they would like to see on a new Suzuki Ute? Sorry if I had you guys going. It's all in fun.
Old Jun 13, 2002 | 04:35 PM
garyc660R's Avatar
Who is gonna use 48rwhp in a utility quad? I cleaned up your signature and removed that nasty little "for sale" ad as well. Later.
Old Jun 13, 2002 | 06:46 PM
LEP7MM's Avatar
first of all, my apologies about the need to edit my profile. Second, the 48 RWHP is just something that I would love to have in a machine that can not only do well in the woods, mud, and at work, but keep up to the sport machines as well. There are a select few such as myself that could make use of a machine such as this. One other feature I would like to see is a built in GPS/Global Mapping system for those trecks into unfamiliar territory when those trees start looking the same. A good set of 4-ply tires would be a plus as well instead of the standard issue 2-ply's.
Sep 30, 2015 01:37 AM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
Elkaholic
Sep 6, 2015 02:44 PM
Riding Gear
Jul 7, 2015 05:03 AM
