little help with lt
Old Aug 4, 2002 | 01:11 PM
tom18801's Avatar
i took the axle out of the bearing carrier and forgot if the rotor goes on the side fo the axle with the raised up lip of the sprocket by the way this is a 1992 lt 250 with axcalibur axle
Old Aug 4, 2002 | 08:38 PM
tom18801's Avatar
cmon guys, gals?
Old Aug 5, 2002 | 01:19 AM
Quadsportman's Avatar
Well the disc goes on the right side of the axle carrier and as far as I know, the axle should slide out from the right side of the carrier. So that means that you would not have had to remove the lip to pull the axle out.
Thats just what I know from my Quadsport 230, it may be different so check and make sure. go to www.ronnies.com and look for their OEM parts. Find your quadracer in the list and then you can see full schematics of every part.
Hope this helps
Old Aug 5, 2002 | 10:40 PM
tom18801's Avatar
so your sayong the rotor goes against the lip? ronnies picture is to crappy to see
Old Aug 6, 2002 | 03:11 AM
WP's Avatar
WP
Go pick up a manual, they are cheap and very helpful.
Old Aug 6, 2002 | 07:42 AM
tom18801's Avatar
hopefully more helpfull than you
Old Aug 6, 2002 | 09:38 AM
theboss33's Avatar
Yes your brake rotor goes against the lip.
Old Aug 6, 2002 | 09:49 PM
tom18801's Avatar
thankyou
Old Aug 6, 2002 | 09:59 PM
WP's Avatar
WP
Blow me Tom. I'm not the one who takes things apart and can't remember how to put them back.
