'92 LT250R Questions, 20:1 Gas Mix? 373 lbs?
Old Aug 13, 2002 | 01:30 AM
mrbones's Avatar
Hello,
I just bought a '92 LT250R. I was reading the owner's manual (yes, it actually came with one!) and it states the engine must be run with a premix of 2 stroke oil of a mix of 20:1. Does this engine need that ratio? That's a lot of oil to be using. Is the standard 32:1 ok?
Also, I keep reading in the archives that the consensus is the LT250R weighs about 320 lbs. I checked the back page of the '92 manual and it says the dry mass is 373 lbs. That's quite a bit heavier. It definately felt heavier picking it up and also trailering it. I can tell the difference from lifting my wife's Blaster that is about 320 lbs. I can only guess that from what I've read in this forum about the LT250Rs, is that the 91-92 (am I right on this?) has a reinforced frame with more gussets and it has a different swingarm, perhaps a heavier one? The '92 also has those big, but useful steel stock nerf bars. But does all this account for another 50 lbs?
Thanks,
!*mr.bones!*
BTW : The '92 I got is 50 bored over with a DG pipe and it sure is FAST! It even has the stock tires on it that aren't worn out! The front ones look new (rear 50%)! And to my delight, a rebuilt rear shock.
Old Aug 13, 2002 | 03:42 PM
dual-sporter's Avatar
i run maxima super-M at 40:1 in my '91. factory specs say 32:1.
as for the weight i know what ya mean about it feeling heavier, but i have never put it on a scale. i don't think that those changes would add 50 lbs, but i could be wrong. evrything i've read says its like 328-330 lbs dry. which would mean ~350 wet.
Old Aug 13, 2002 | 03:48 PM
Trixterboy's Avatar
I run 40:1 blenzal and no trouble. I'm with you mine has the little sticker on the tank that says 20:1 and it made me wonder but everybody I talked to run 32 or 40:1. Later
Old Aug 28, 2002 | 01:40 PM
mrbones's Avatar
Thanks. I'll use the standard 32:1.
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Levi Enstad
Sep 26, 2015 08:00 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
