neutral from third on zilla
Old Aug 17, 2002 | 09:09 AM
stormnorm's Avatar
Can any of you zilla owners get neutral from third when pushing down lightly on the shifter? When I push down all the way I get second (of course ) but pushing down lightly will get me into neutral and that has me worried. The trany works fine otherwise.
Old Aug 17, 2002 | 11:39 AM
Triple's Avatar
What you describe is called a "false neutral". You are not in the actual neutral. If this is a problem that crops-up often, I would suggest cracking the motor open. The problem may be found under the clutch cover with the shifting mechanism there. However, I would guess the culprit is deeper. Your shift forks may be worn or otherwise damaged. To check and replace them requires splitting the cases.
95wolv
Sep 27, 2024 12:00 PM
Dammar
Apr 20, 2016 06:03 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Alex G.
Sep 19, 2015 06:34 PM
