Vinson Reliability and so on
HUNTFISHALASKA....please note you are violating forum rules by PM'ing fellow members using slandering and insulting comments. If your posts and PM's don't clean up, there will be no choice but too remove you from the forums member list. Please be careful on that beast and have a good day.
#16
Here's a bit more feed back. My step father has an 02. Like the others say the shifter was a bit weird at first but is fine now. However the only complaint he has would be with the rear brakes. They will not stop squealing. He is looking to put a better pad on there so that should (hopefully) take care of that problem. As far as power, handling, reliability I have no complaint at all.
I would buy one with out a doubt.
Good Luck
Marc.
Good Luck
Marc.
#18
My rear brakes were sqeaky early on, but I took it to the dealer and they cleaned the pads/rotor under warranty. No problem since then. They say it will be necessary to occasionally remove the caliper and clean out any junk in the pad. Overall a great machine!
