Eiger oil change ?
Old Aug 22, 2002 | 07:51 PM
BK's Avatar
BK
Does anyone know of a place to get a cheaper oil filter for the Eiger? Is there a automotive one that will cross reference? Also, when you check the oil, do you check it with dipstick srewed in or out? Thanks!
Old Aug 22, 2002 | 09:59 PM
BuggyBrian's Avatar
My dealer had a aftermarket one. $7 instead of $13. It's made by HiFlo and I think the # is 140138. Looked just like the factory. Even had the same #'s stamped in the top. Fram, K&N, and a few others make them though.
Old Aug 22, 2002 | 11:06 PM
SharpEiger's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img] The best oil filter I have found for anything is by WIX, the WIX number for the Eiger is 51359 and is alot cheaper than the Suzuki, Also found the the best oil currently is by Royal Purple, I am running the 15W40 during the summer heat here in Missouri.
Old Dec 24, 2002 | 10:23 AM
Kupashaw's Avatar
Default Eiger oil change ?
Probably the best place to get Wix filters is Napa, which the # should be 1359. The only thing you may want to check is comparing the old filter to the new one.
Old Dec 25, 2002 | 04:25 PM
Dewbaby's Avatar
You just place the dipstick in the oil port and do not screw it down to check the oil. Page 58 in the August 2002 version of the manual. The oil filter cap threads are not run in but touching the filler hole upper edge.
Old Dec 25, 2002 | 04:28 PM
Dewbaby's Avatar
Why do you say that Royal Purple is the best oil? What do you base that on? Not a flame, I was wondering if you had bad luck with some other oil.
Old Dec 25, 2002 | 07:14 PM
STAKK's Avatar
Is it true the Eiger takes over 6 quart's of oil at an oil change? man that's alot if it's true......
Old Dec 25, 2002 | 07:40 PM
Dewbaby's Avatar
Eiger takes 3.4 quarts. I don't where that 6 qt thing got started.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
