Z400 or KFX400 in mud?
Old Sep 9, 2002 | 05:45 PM
RubiconMan500's Avatar
Has anybody taken their Z or KFX in the mud? If so what kind of wheels do you have, and/or mods?
Old Sep 9, 2002 | 07:09 PM
vooduuchild's Avatar
I've taken mine in lots'o mud as it tends to rain a lot here in Washington state. It's a stock machine for now, but I will be putting on some 22's, dropping the front sprocket to a 13 and taking the rear to either a 41 or 42. Dunno which though yet. I can't wait to get some more clearance so I don't have to worry so much about dang ruts!
Old Sep 9, 2002 | 08:46 PM
does it do good in mud? get stuck alot?
Old Sep 9, 2002 | 09:45 PM
QUADZZUKI's Avatar
I ride alot of mud and I was surprized how well the Z does in the mud since it doesnt have that much ground clearance. I would say that it is as good as any other 2wd quad out there for mud and when I put 22 inch tires on, it will be even better.
Old Sep 9, 2002 | 10:30 PM
SuZuKiZ400RiDeR's Avatar
Besides for ground clearance what else will a 22 inch tire do for you on the rear? I was thinking more of a 20 for me or maybe even an 18. Let me know.
Knowles
Old Sep 10, 2002 | 10:03 PM
QUADZZUKI's Avatar
Other than ground clearance the 22 inch rear will give you a higher top speed if you stick with your standard sprockets but im planning on going to a 13T front sprocket, that should keep the gearing power similar to stock. If you are planning on only mx racing or riding flat ground 18 inch rears would be best. I will eventually get a set of 18 inch for myself so i can throw them on when I go to the track.
Old Sep 11, 2002 | 12:35 AM
Z400Fan's Avatar
I have taken my z in the mud here in El Paso. The stock clearance is good enough for my needs. The occasional flash flood pushes the z to the limit, but she holds up fine.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
Lou Domenech
Sep 11, 2015 06:35 PM
1ArmBandit
Sep 8, 2015 08:59 PM
Brandon400
Sep 5, 2015 08:44 PM
