Help! Quad runner 160
Old Sep 19, 2002 | 07:39 PM
SuzukiQuadrunner160F's Avatar
I own a 92 Suzuki quadrunner LT 160 it runs for a bit then will cut out and stall with some throttle and won't idole. is it overheating, needs an oil change, or are the rigs gone? i think its a oil change. Help is appriciated.
Old Sep 19, 2002 | 09:47 PM
yamahagye's Avatar
Changing the oil will not help.
Take the carb apart(or find someone who will) and check to make sure none of the jets are clogged and also make sure the float is not sticking. Also remove your fuel line and blow compressed air through it just to make sure the hose is not clogged. It souds like it is only running off the gas in the float bowl which would mean something is sticking or clogged. Maybe you need to change your spark plug. Also check and clean the air filter.
BTW. IT would be a good idea to check and change the oil every so often.
JaMeS
Old Sep 19, 2002 | 10:12 PM
Raptoryfn660r's Avatar
RIP Dear Friend
<< Changing the oil will not help.
JaMeS
I check the fluid levels after each ride.
I change the oil in the FACILITIES quads and dirtbikes all the time. Cheap insurance. Each one has a log book with the hours kept and written down after every ride.
Chet
VP KNOWSALOT FACILITY
Old Sep 19, 2002 | 11:17 PM
yamahagye's Avatar
What I meant is that anything involving the oil will not make it stall out (unless it is frying a piston[img]i/expressions/face-icon-small-shocked.gif[/img] ).
When I said it would be a good idea to check the oil every so often, I was being sarcastic. He SHOULD check the oil quite often, but I was implying that it is better to check the oil every once in a while than never.
JaMeS
Old Sep 19, 2002 | 11:46 PM
RIP Dear Friend
yamahagye,
When I haven't checked my oil its has been one of those night rides to watch the missiles go off.
First thing in the morning I pumping dipsticks.
In and Out,
wipe that baby out
Now the sump is full
so Chet don't have to pull.
Pull as in Chet don't want no stranded quad because of not checking the oil.
Chet
Old Sep 21, 2002 | 03:16 PM
Thanks for the help, turs out it was a clogged fuel line. I changed the oil and everything first tho. What was I thinking nothing can go wrong with a suzuki motor.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
Ashley S
May 29, 2017 10:54 AM
vlkster
Jul 28, 2015 11:35 AM
Chillibean
Jul 26, 2015 09:47 AM
