LT 250 jetting
Old Sep 25, 2002 | 06:25 AM
kevdawg's Avatar
I've got an 88 LT 250 with: a boysen rad valve, and a keihin 34 carb, FMF gold series pipe and silencer, and a K&N filter with no airbox. I'm having jet problems since adding the pipes. In Glamis i used to run stock needle and pilot and a 135 main jet. Now i have no clue it seems super lean on the low end because when I stop the engine races out of control. i had like a 152 in and it didn't seem fat but cut out on the top end. I moved the needle to the top clip and that still didn't seem to do much. I'm not real knowledgable on jetting so should I increase the pilot jet or do I have another problem?
Any feed back on this problem would be helpful.
Old Sep 25, 2002 | 08:35 AM
lt250r91's Avatar
Go to duncan's website Duncan Racing and read there piece on 2-stroke jetting. It sounds like you need to move the needle clip down to richen up the mixture. I would check with duncan to be sure though. I don't have a ton of experience with carbs. I like to let the mechanic do that.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
