Dyna-jet kit availability
Does anybody know if there is a dynajet kit available for the Z400?
Just a replacement for the unadjustable needle would be nice.
Also, does anybody know what the output of the stator is??? nothing mentioned in the owners manual.
Corpsi,
Thanks for the info. I usually don't use the dynajet kit but I figured it would be worth it this time to get the needle. Speaking of the needle, is there enough room to put the washers on? I figured that the needle retainer would not lock into place if I made that area thicker as adding washers would do. Did you have a problem pushing the needle retainer back into place with extra washers?
I took the filter cover off, added a WB E-series pipe and now its major lean. I'm thinking a 140 main and raise the needle 2-3 washers or clip positions.
Yep, there is plenty of room for the two No. 4 washers. Remember, adding the washers is equivalent to moving the clip down on an adjustable needle. I had no problems putting it back together. This is my first experience with a carb, so I'm not some pro who has done this before. Everything I have done, everyone can do.
Ack, zookyridr is telling you my set up. ( [img]i/expressions/face-icon-small-tongue.gif[/img] to zookyridr)
If you're going a Unifilter or K&N, you'll definitely need a 152.5
A 140 will be WAAAAAY lean.
You just saved me a s**t load of work and trips to the bike shop. I never would have guessed that I needed to go that high on the main. I'm thinkin this thing is gunna rip without all the restrictions...jetted right that is.
Thanks to you both for the info.
